I received today one 2.0 base station and index controllers. I have had no problem pairing them in pitool and steam but my controllers are reversed. I need to set the base station behind me to have the controllers in the right place facing front. The trouble is the tracking is poor because the base station is behind and I shadow the controllers and sometimes the hmd with my body and chair.
How can I configure my base station to set it in front of me? Many thanks for your advice.
Interesting. Can’t help you though.
How about setting your BS upside down?
By reversed I assume you mean that the left controller appears to right hand and vice versa?
If thats the case, try powering the controllers up in different order.
