Hello everybody, this is my first post, I have just bought PIMAX 4k and before installing it in my PC with OS Windows 10, I want to know if PIMAX 4K can be installed if Oculus Rift is already installed in the PC.
Thank you very much for your help!
There should not be any problems.
Thank you, my question was raised because I saw a tutorial in youtube that said that Oculus services had to be stopped in order to install PIMAX 4k.
can you share the link to that video and we can see if its an old one and if it impacts on the current pitool versions?
It is in Spanish, but let’s go:
https://www.youtube.com/watch?v=Iaju4q_MFtQ
Hi there,
That video is 2 years old and pitool has moved on from those old piplay drivers
so you should be ok to install as is with Oculus already being installed.
Eno
