This has probably been asked and answered before, but i didnt know how to search correctly to find the answer to this question.
so assuing the 5K resolution is spread across a fov of 170 degree in the large fov, what happens when i change to a smaller fov? does the picture get cut and we loose part of the 5k resolution? basically will the smaller fov have less resolution?
or will the smaller fov display the full resolution of 5k?
That’s why the smaller FOV’s are less taxing on the pimax when changed. If the large FOV will never be usable, it would have been nice to issue panels at 150FOV but same res for even more pixel density though with no 170 degree option haha
You’re right, but most people don’t seem to mind. I’d guess they’d have gotten a lot of pushback if only normal FOV was available now.
While the difference between 150 and 170 is supposedly not very noticable, full FOV has also more distortion.
