Are you using the DMAS with an 8KX? The DMAS are high-impedance speakers and don’t work in standard audio ports. Plugging regular headphones into an 8KX would result in extremely loud sound (and may damage the headphones).
Try adjusting the volume via the 8KX volume buttons. I noticed that the headphones ignore the main Windows volume setting. You must use the headset buttons to adjust the volume.
I have the DMAS plugged into their respective ports on the headset itself(left and right side). Using your advice I did get the left side to work but no audio comes out of my right side.
Yes! That helped! I reseated the right headphone and screwed it back in. Pushing it back down after that activated them and its all working now. Thank you so much
If You don’t impedance match You’ll get noise (as far as I recall the rule of thumb is that the input impedance has to be at least 8 times higher than the output impedance).
If You plug low impedance IEMs into a desktop headphone amplifier You’ll also experience noise.
I think they haven’t properly matched the output impedance with the input impedance and since it’s only a problem for some there might be different revisions of the internal DAC/Amp.
Besides that impedance is not what causes headphones to “require more power”.
It’s usually their sensitivity (or a combination).
I have 50 ohm planar magnetic headphones that are harder to drive than 150 ohm headphones due to lower sensitivity…
Lastly: I’m no Audio Guru either but it’s been my hobby for quite a few years and I own 30+ IEMs and earbuds, ~20 headphones and a handful of headphone amps (both solid state and tube)…
