I’m about to test it, but wanted to let you guys know.
It’s a built-in update, just launch Pitool and it will let you upgrade under settings.
Sadly, I only see 3 options for the brighness setting (High, Normal, Low), not a slider.
Interesting, thanks for the heads-up and please do report on your findings.
Interesting, @Doman.Chen do you know what is default value of old version?
http://piplay-us.pimaxvr.com/PiToolSetup_181_95.exe
Here’s the direct link guys.
What is the low-high slider then?
I will try to set the high brightness to check that the black dot will come to see easier or not.
May low brightness for testing the black level.
This is pitool SS…
They change from 0.5, 1, 2 value?
Well, just did some testing with Elite and the difference between high and low is so subtle I had to go back and forth to convince myself it’s there.
It’s certainly not night and day difference (pun intended).
On the positive side, the tracking detection is now near instantaneous - the lighthouse icons light up almost immediately.
Side-note: there is a strange effect after starting an application, which looks like I’m looking at the world throuhg 4 separate panes of glass. It goes away after I turn my head a couple of times, but it’s strange regardless. Does anyone else see this? I can’t remember seeing this before.
Ever found big distortion at left and right which can see easily
Well, that deserve some praise !
Cheers Pimax and happy good year.
The default value of old version is normal.
Can you guys please add color options? It’s needed for the 5k+
Just tested low brighness in ED - effect is there , definitely screen is dimmed.
But imho it dosn’t helped this game too munch because we need saturation bump up if brightness if dimmed.
Not sure but also observed more geometry distortions (?!)
@Sean.Huang Any chances for saturation an colors changes in next PiTool ver. ?
Did you try closing/reopening everything (like when you change the FOV)?
Yes, even rebooted the headset and Pitool itself.
I want to know that what value in Pitool can be change without restarter steamvr?
- paraller projection
- quality
- fov
- brightness
All of that needs a restart of steamVR afaik
Edit: Thank to @Yata_PL we now know that all except brightness settings need a restart
OMGoodness. My replacement Pimax comes tomorrow. Looking forward to trying this
I haven’t heard anything about my replacement at all. What did they say to you before shipping one?
