New piplay....?
Wow i install the new piplay 1.1.87 and in pimax mode there is no image on it, but i see image on both steamVR and virtual destop mirrors!! Weird…
Have you tried restarting ? Switch of the headset. Switch back on.
The light it blue when i watch it and yes i restarted some time and same result!!
Can you post pictures… I don’t know what you mean fully.
You say your light is blue?
You could try device manager removing the monitors and rescanning.
I could maybe give more suggestion if we figure what we r up against. :slight_smile:
I mean everything work fine but i dont see any image in the pimax (google), i open steamVR and virtual desktop mirrors and i can see my google moving!! But when i put it a extend mode i see image in my pimax!! In direct mode i see image in steamVR but virtual desktop dosnt work!!
Wow ok i fund the problem it the klite codec!! It ok now!! Dont install klite from the codec site!!
Glad you got it sorted. I think when I installed new piplay it automatically uninstalled that codex for me. I remember a message.
Nicely worked out. Have fun
