It breaks Pimax backlight brightness adjustment when .86 V7 is installed with 0.70 PE. It goes to default brightness but at least the ghosting is eliminated. I actually prefer a ghosting free picture over higher brightness. But I hope Pimax releases new firmware that allows us to increase brightness without introducing the ghosting issue.
After restarting the headset, backlight adjustment works perfectly and the ghosting is gone too!
The ghosting was apparently only noticeable at higher brightnesses. I had it set to 80 and didn’t notice any ghosting (but I did reboot the headset, since I ran into firmware flashing issues).
Hmm I guess your 8KX headset haven’t updated to the latest firmware. Im pretty sure its supposed to auto-update to this version with latest PiTool, but in case it didn’t, here is the file:
And now you know. Whats weird is that they had no problem labelling Pitool .87v2🤪
I don’t think it was unthinkable that I made this mistake, as I was under the impression that backlight adjustment was a feature that was for all headsets.
but now i see a special version of it just for 8kx is the one where its enabled.
That other version of 294 … are its features included in the 8kx one?
Don’t want to kill the fun here, but we still need some more help from Nvidia to get higher refreshrate to work with 8KX. It not impossible, but they need more time it seems.
