yea i just got a Pimax 4k but i can not get steam vr to use it just says put on your headset to wake vr… What do i do to get it to work?
What version of piplay/pitool are you using… Also what is your pc/laptop spec? You need to ensure that you are connected to the dedicated GPU. And that pitool has no errors.
