Need replacement HDMI/USB cable, where the hell do I get it?
Recently my Pimax 4K wouldn’t turn on, but I managed to solve the problem by opening the damn thing up and using different cables. How the hell am I supposed to fix this? Is there anywhere I can buy a replacement cable? Is there any chance I could get a replacement cable? Also, how do cables break so easily. :sweat_smile:
@Pimax-Support @bacon @Sean.Huang @deletedpimaxrep1
Added some pokes to your post. Myself? U would look into seeing if you could find 2 short cables with female ends.
Support might be able to help with official cable replacement.
Yeah, preferably I can get an official replacement, otherwise I’m just gonna get a right angle HDMI and a really thin USB.
