Hi Guys I really need that Pi Tool Software where I could adjust the black levels of my Pimax Xr Oled HMD. I searched the whole google but every links is down
Edit : Found a new pi tool version on the website
Worked perfectly
Its very Important btw to dissable Hardware accelarated gpu in windows to get rid of the micro stutters.
Its still is an amaizing hmd and runs awesome on the rtx 4090 !
Yeah it’s the newest Pi Tool software Version: v1.0.1.270
I took me 5 years btw to find out that I have to deactivate gpu accelerated planing in windows to use this headset properly without any jittering in tracking
Okay that pitool might be last one(not sure) but is almost 2 years old.
You would want the latest pimax play to ensure full compatibility with PimaxXR unless your using an older version.(as recommended and stated by @mbucchia )
Yeah finally after all these years it’s still a great hmd even to this day . In my opinion it shouldn’t have been discontinued since it’s absolutely unique on planet earth . I mean it’s 200° oled. If it would be a little bit sharper and with updated more expensive panels it would be the best hmd .
Except as mbucchia has told pimax they need to be telling users to use pimax play client latest version with PimaxXR since the team is not updating pitool and the latest versions of PimaxXR will not work properly as Pitool is lacking the needed updates.
No Pimax Play should work fine with the older headsets as Pimax Client was fine
I have used my 8kX with earlier versions of pimax play/pimax client.
Pitool has been more or less discontinued. The new pimax software is likely not compatible with pimax’s first series headsets like the p4k that was still mostly supported still in pitool.
