So i tested Project Cars yestarday evening, and besides usuall piservice crashes, everything worked more or less ok. Today, i wanted to check if i can find a solution to blurry image problem, but the headset didnt want to work at all.
First, after starting PCars i saw some fucked up graphics in the headset, so i rebooted computer. Since then, all i can see is “piservice stopped working” windows message or “where is my pimax” message in piplay. I tried to update its firmware using command line and dfu mode, but it says it found 0 devices.
Im probably about to send back this pos, becouse although i didnt expect quality product from some china manufacture, this is just ridiculous.
EDIT: Offcourse i tried to reinstall software n times.
