Cannot get pass the initial VR selected screen… long winded story below with MSSupport. Any ideas on what I can try next?
i7-9700K - 3.6Ghz, #2GB RAM, RTX2080
ONLY gets me as far as “press Spacebar to Centre”
Your request (#146260) has been updated. To add additional comments, reply to this email or click the link below:
https://flightsimulator.zendesk.com/hc/requests/146260
Microsoft Flight Simulator Support Team (Microsoft Flight Simulator)
Feb 10, 2022, 15:16 GMT+1
Hi Menendez
Thanks for contacting Microsoft Flight Simulator Support today.
Microsoft Flight Simulator is compatible with headsets that support OpenXR such as Windows Mixed Reality headsets, Oculus headsets, SteamVR headsets.
The sim has been optimized for the following headsets:
HP Reverb G2
HP Reverb G1
Samsung Odyssey+
Your Pimax Headset doesn’t officially support OpenXR. Therefore we cannot guarantee that it will be compatible with Microsoft Flight Simulator.
Kind regards,
MSFS_Erik
Menendez
Feb 9, 2022, 5:40 GMT+1
Please help
Sent: Sunday, 6 February 2022 11:16 AM
To: ‘FlightSimulator’ <support+id146260@flightsimulator.zendesk.com>
Subject: RE: [Microsoft Flight Simulator - Request received] Cannot run MSFS2020 on my newly acquired 8KX.
Importance: High
Hi Support
Any suggestions for me please?
Problem is not resolved
Cheers
“George”
Sent: Monday, 31 January 2022 11:05 PM
To: Menendez <menendez@bigpond.net.au>
Subject: [Microsoft Flight Simulator - Request received] Cannot run MSFS2020 on my newly acquired 8KX.
##- Please type your reply above this line -##
Hi Menendez,
Thank you for contacting Microsoft Flight Simulator Support. Your request (146260) has been received. Our team will respond as soon as they are able.
For 24/7 assistance, visit the Microsoft Flight Simulator Knowledge base and the [Official Forums](https://forums.flightsimulator.com/c/virt
Menendez
Jan 31, 2022, 13:04 GMT+1
Cannot run MSFS2020 on my newly acquired PIMAX 8KX… ONLY gets me as far as “press Spacebar to Centre” as per photo attached…
Pimax headset works great on other games…
PiTool Info
Version V1.0.1.271 Headset Firmware V2.1.255.298 …
Am I doing something wrong in the set up somehow?
CPU i7-9700K-3.6Ghz with 32Gb RAM DDR4, RTX2080, Evo970SSD…DxDiag attached for full system details… would be much appreciated if you can make some suggestions on how to or setup settings please.
Display mode … Full Screen
F.S. Resolution …1920x1080
Render Scaling … 100%
V - SYNC … OFF
Frame rate … … …greyed out ( 60FPS? )
HDR 10 … …greyed out ( OFF ? )
Direct X version … 11
Global Rendering … Medium
Anti Liasing … …TAA
Terrain level of Detail … 50%
Off Screen Terrain Pre Caching … LOW
Terrain Vector Data … LOW
Buildings … … … …LOW
Trees…LOW
Grass and Bushes …LOW
Objects level of detail 50%
Volumetric Clouds … LOW
Texture Resolutions …LOW
Anisotropic Filtering …16X
Texture SuperSampler…6x6
Texture Synthesis … …LOW
Water Waves … … … … LOW
Shadow MAps … 1024
Terain Shadows …256
Contact Shad0ows …LOW
Ambient Occlusions… LOW
Cubemap Reflections …128
Raymarched Reflections … LOW
Light Shafts… …LOW
Bloom… …OFF
Depth of Field …Medium
Motion Blur …Medium
Lens Correctyion… OFF
Lens Flare …OFF
Glass Cockpit Refresh rATE …LOW
Seems to idle at 160FPS on the welcome screen
PiTOOL on Games TAB /Microsoft Flight Simulator
Refresh rate set at 60Hz
Any comments would be very welcomed… I was using a HP Reverb G1 previously but it was consistently unreliable over 12 months and VERY frustrating to get working every time so purchased a PIMAX 8KX as my next move forward.
Attachment(s)
DxDiag-Jan30-2022.txt
This email is a service from Microsoft Flight Simulator. Delivered by Zendesk
[ER64YZ-G4YD]
Support (Microsoft Flight Simulator)
Feb 6, 2022, 1:34 GMT+1
Hi Menendez,
Thank you again for contacting Microsoft Flight Simulator Support today and bringing this matter to our attention. We will need to review the information before coming back to you. We appreciate your patience while we forward your message to our team of experts. Depending on the complexity of your question/issue, they may need several working days before being able to come back to you.
Kind regards,
Knowledge base Twitter Facebook Discord SDK Q&A
MSFS_Jordan
Menendez
Feb 6, 2022, 1:16 GMT+1
Hi Support
Cheers
“George”
Feb 5, 2022, 21:54 GMT+1
Hi Menendez,
Thank you again for contacting Microsoft Flight Simulator Support; we sincerely apologize for the delayed response. Please have a look at our general VR troubleshooting steps below.
To troubleshoot performance issues, please do the following first:
Close Microsoft Flight Simulator
In the “Type here to search” field, next to the start menu, type " OpenXR "
In the menu, select Uninstall
Go to Microsoft Apps and click Get
Re-install OpenXR.
Go to your headset manufacturer’s website
Download the latest drivers for your headset
Reboot the computer
Launch your VR headset application .
Launch Microsoft Flight Simulator
Put your headset on.
Enter the command to switch to VR (please check your bindings for VR in the ‘VR Mode’ tab in Options > General) or click on the button in the ‘VR Mode’ tab in Options > General.
If the problem persists after that, please move on to the following troubleshooting steps:
“THE INITIALIZATION OF VR FAILED” ERROR MESSAGE
From your computer, open the SteamVR app
Head to Settings
Select Show in Advanced Settings
Head to the Developer tab
Click on Select SteamVR as OpenXR runtime
CTD WHEN SWITCHING TO VR
Close ATC windows and other pop-up windows before switching to VR
Switch from Window Mode to Fullscreen mode
CRASH ON STEAM
Open Steam.
Go to Steam settings > In-Game
Uncheck the "Use Desktop Theater box when launching desktop games while SteamVr is active.
UNABLE TO SWITCH TO VR DURING A FLIGHT
Please verify that your headset is connected correctly and ready to use. You can check your headset’s connection by launching your respective platform’s app. For example, this is the Mixed Reality Portal for Windows Mixed Reality.
FRAMERATE DROPPING AFTER SWITCHING TO VR
There are two graphics settings in the sim: one for the desktop and the other for VR. When you switch between the two modes, the sim dynamically switches settings, briefly impacting its performance.
HOW TO INCREASE THE FRAME RATE.
Render Scale has the most significant impact on the framerate, especially when using higher-resolution headsets.
Reduce the traffic settings in the VR Traffic options (deactivated by default in VR).
Update your graphic drivers to the latest version.
Reduce the graphics settings under VR Graphics options.
LOSING MOUSE AND KEYBOARD INPUT
We recommend using manual input switching if you are using a Windows Mixed Reality headset. In the “Headset display” tab under the “Input switching” section, you can configure this option in the Mixed Reality Portal options.
If you are using a Windows Mixed Reality headset, our input may have been automatically redirected to the Windows Mixed Reality Portal after wearing the headset. The “Win + Y” shortcut will switch focus back to the desktop.
BLACK STENCILS - OCULUS HEADSETS
Update to the latest Beta version of the Oculus software, which should solve the issue. When seeing black stencils in your Oculus view:
If that doesn’t work:
Go to the Oculus Debug tool (Default folder should be C:\Program Files\Oculus\Support\oculus-diagnostics)
Open the Oculus Debug Tool
Turn the option “Use FOV Stencil” to Off
Disable/enable VR in MSFS
YELLOW SCREEN
HDR causes this. We have a fix in the works, but for now, we recommend you deactivate HDR when playing in VR.
BLACK SCREEN
HDR also causes this. Turn off HDR on Windows and in the sim. The HDR option should be disabled in VR graphics.
NO SOUND DURING FLIGHTS
Please see this solution shared on the forums: https://forums.flightsimulator.com/t/sound-no-longer-working-during-flights-12-23-2020/339594/20
If the issue persists after doing all of the above, please re-open this ticket, and we’ll investigate further.
Best regards,
MSFS_Jordan
Menendez
PiTool Info
V - SYNC … OFF
Anti Liasing … …TAA
Trees…LOW
Shadow MAps … 1024
Terain Shadows …256
Light Shafts… …LOW
Bloom… …OFF
Motion Blur …Medium
Lens Flare …OFF
Attachment(s)
