Dear all,
I have just received the final 8k Plus! Here is the unboxing!
Of course, going to give this a thorough review as well. But that will take some time!
Bye, Sebastian
Dear all,
Bye, Sebastian
It’s going to be interesting to hear if there’s distortion difference between this headset and the 8k-X in your opinion, given that they have the same lenses and panels …
Good point as the 8k+ is final and should be what the X should be once finalized.
Question. i thought that the new vision headsest would use 2 usb and 1 display port. now i see videos with power adapter.
pimax 8kx will have one adapter and on usb or 2 usbs?
@PimaxQuorra can you answer?
The 8kX is currently the only Vision headset that has removed the need for an external 12v adapter.
ok i didnt know it. thanks for the answer.
The 8K-X needed a new, higher-quality cable (aka expensive) to meet the bandwidth requirements/etc. The other headsets didn’t need the expensive cable to work properly, so they just used the old cable.
