Its been known in the research for quite some time that Monoscopic rendering is not ideal for a static shot like a 360 degree Photo (although its still usable, as I’ve tested with multiple depth sensitive monoscopic 360 images) but when there is motion, the visual system is able to infer depth from a monoscopic view.
We see this all the time on 2D displays that have a high resolution video source displayed, like 4K blu ray. Texture gradient in this case is the monoscopic cue we use to sense depth.
I think for these HMDs a monoscopic rendering mode could solve the gulf between 5K+ and the 8k, and even let us push a much higher frame rate, stable current frame rate, or a higher SS level, or both. This could also potentially help the Pimax 8K push a higher native resolution on its display.
A lack of Stereo 3D isn’t always noticeable, especially in simulator games. Many professional flight simulators for example are only monoscopic.
The majority of the Pimax FOV in the periphery is already monoscopic, so why not offer the option in software to save on the rendering cost?
Its also true that the majority of depth cues in human vision are monoscopic. You could even offer a faux 3D effect like Tridef 3D’s or VORPX’s power 3D mode, where the program is using Z buffer data to create a depth map for a 2D image to appear 3D.
Since the Pimax has such a large FOV, I don’t think a monoscopic rendering mode would see much of a downside on “low end” cards like GTX 1070.
Titans of Space was an early app on the Note 4 Gear VR that needed to run in a monoscopic mode to be able to run within the hardware constraints, and not overheat the device. From personal experience, you could still infer depth just fine, particularly when moving because your visual system relies on several cues for depth, other than stereoscopy.
Even someone who is stereo blind can enjoy VR
https://pexlab.wp.st-andrews.ac.uk/2013/10/28/question-1/
https://www.scotsman.com/news/scots-scientists-people-can-see-3d-with-one-eye-1-3140843
http://www.drashvr.com/2014/11/titans-of-space-update-plus-tough-gear.html
Maybe this would be worth a shot. What do you think @deletedpimaxrep1 @Heliosurge @SweViver
