I’m not sure if this is built in, but is there a Microphone built into the Pimax 5k+ anywhere?
The reason why I’m asking is because I was looking into getting the iSine VR Earbuds which seem like a great option since it just plugs into the 3.5mm port, but there’s no microphone in the earbuds, so I was wondering if there is one built into the Pimax 5k+ somewhere?
I think there should be, there is a little hole by the model sticker that I think corresponds to the microphone. I’m still using my previous headphones for sound though so I don’t know.
Actually, I like Oculus way of dealing with sound on GO, and new Rift S, and Quest! It is so convenient while testing some games or when you are on your own quite room…
However the best is Vive DAS/original Rift solution…
Maybe Pimax can have this GO/Quest/Rift S integrated audio speaker solution. Should not cost a lot…
Sating this, kudos to Pimax for microphone quality… What were thinkung Vive guys on even Pro to chose the worst mic quality? Even my external mic for 2 dollars from aliexpress is so so much better…
