What graphics cards do you think is required to get maximum graphical quality from pimax 5k plus and Pimax 8k and Pimax 8kx headsets in Pitool
Also what approximate graphical resolutions/quality are possible with each card.
- GTX1070
2.GTX1070 X 2 IN SLI
3.GTX1080
4.GTX1080 X 2 IN SLI
5 RTX2080
6.RTX2080 X 2 IN NV LINK
7.RTX2080TI
8.RTX2080 TI X 2 IN NV LINK
9.AMD CARDS? PLEASE STATE
Better to post Games & or programs.
NV link/sli x2 Nvidia cards not much point as Game needs to support it.
@VoodooDE had tried 2×2080ti & had concluded at the time not worth it.
Amd cards results still not on par on Pimax; they work well on other headsets. Amd & pimax are supposed to be working on fixing issues on Rx - current amd gpus. Something in changes to Architecture after the r9 390 not working as well as it should with pimax headsets.
