I’m going to use Pimax 4K for the work, and there is a requirement to keep volume maximum.
Is there the way to keep volume?
From code, or PiPlay settings?
Thank you.
Thank you.
Thank you for your assistance IrisChen, but there are 2 volume multipliers on the Pimax.
First one is you said, volume slider in Windows.
Second one are the buttons on Pimax.
I want to control second one from software.
Hi, just now I confirmed with our software engineer who said that it’s hard to fulfill this feature at present, sorry for inconvenience.
Hi, Pimax-Support.
Thank you for your confirmation! I understood that.
I’m looking forward to being implemented someday.
My pleasure. I will report your request to our debugging system also : )
