Load and performance figures from IL-2
Hi,
Since I’m on the fence buying a new VR headset I read everything I can about the interesting ones. I came across this performance test in IL-2 forum today.
Perhaps someone can enlighten why pimax load is not increased and frames are low?
This problem has been confirmed as a Windows bug, which affects other VR headsets and apparently non-VR systems as well. Microsoft has found a solution and will push a Windows Update with the fix (eventually). Microsoft has said the fix will be available by “the end of August”.
https://community.openmr.ai/t/the-gpu-utilization-boost-is-not-only-working-with-dcs-world-it-works-in-steamvr-games-too/19960/171?u=neal_white_iii
Thanks for the swift reply mate :smiley:
