Live for speed in 2k ? Possibpe confirmation
So live for speed has a native vr option. I dug out a old stearing wheel to see how it all looks and feels.
While being a old game, seems to be a pretty great driving sim.
Any way while looking through graphics options it says the output resolution is 2160 x 1920 which is 2k ?
This is playing in pimax mode.
So this would be the first vr headset to play a vr ready game at 2k ?
Anyways check it out if you can, lots of fun
Screen shot of the resolution.
You will tell us if it is in 2K.
As far as I can tell it is. That’s as much confirmation as I can get.
You cab try it yourself. The game is downloadable from the developers sight. You can get access to one car and one track in the demo. Its a great vr experience. I ended up buying it and I’m not even a car person but the thrill of going nearly 200 mph is a pretty amazing rush.
All you need to so is install it and go into display and change it to vr. And away you go.
I didn’t find VR i found 3D.
2K is 2048 x 1080
Follow this guide if you need a step by step
Remember google is your friend
http://www.vrcircle.com/post/how-to-setup-and-configure-live-for-speed-on-the-oculus-rift
