It has grown considerably in size, now 6Mb - which means it is too large for Pastebin to accept - I hope it doesnât endlessly append instead of creating / rotating new log files, otherwise it will become unmanageable @SweViver
I see output_log.txt has not updated at all and has an old datestamp, so I guess this file is not useful.
Here is an excerpt from then end, including an unhandled exception error that repeats periodically:
2020-10-01 22:11:02:982 :[Debug] PiTool responded! Active settings: {
âblackEnableâ: false,
âbrightnessleftâ: 0.03999999910593033,
âbrightnessleft_Bâ: 0,
âbrightnessleft_Gâ: 0,
âbrightnessleft_Râ: 0,
âbrightnessrightâ: 0.03999999910593033,
âbrightnessright_Bâ: 0,
âbrightnessright_Gâ: 0,
âbrightnessright_Râ: 0,
âcolorChannelValueâ: 0,
âcomboFov1â: 1,
âcomparaproâ: false,
âcontrastleftâ: -0.20000000298023224,
âcontrastleft_Bâ: 0,
âcontrastleft_Gâ: 0,
âcontrastleft_Râ: 0,
âcontrastrightâ: -0.20000000298023224,
âcontrastright_Bâ: 0,
âcontrastright_Gâ: 0,
âcontrastright_Râ: 0,
âcurrentRefreshIndexâ: 0,
âdisplayNameâ: âPimax Vision 8K Xâ,
âdisplayqualityâ: 1,
âfoveatedâ: true,
âfoveatedSupportâ: true,
âfoveatedcomâ: 2,
âheadTrackedâ: true,
âhiddenareaâ: true,
âhomeSupportâ: true,
âipdâ: -0.0005000000237487257,
âpanelModeâ: 0,
ârefreshValuesâ: â75â,
âsmartfillâ: true,
âstartaloneâ: true,
âsuppervivegameâ: false,
âsupportFoveatedâ: true,
âtitleâ: âHalf-Life-Alyxâ,
âverticalOffsetLeftâ: 0,
âverticalOffsetRightâ: 0
(Filename: C:\buildslave\unity\build\Runtime/Export/Debug/Debug.bindings.h Line: 35)
2020-10-01 22:11:02:996 :[Debug] Main-Settings updated!
2020-10-01 22:11:02:996 :[Debug] Updating/Refreshing Quick-SettingsâŚ
2020-10-01 22:11:03:016 :[Debug] Quick-Settings updated!
2020-10-01 22:11:03:016 :[Debug] Initializing HMD values from PiToolâŚ
NullReferenceException: Object reference not set to an instance of an object
at AdvancedSettingsScripts.initHMDValuesFromPiTool () [0x00065] in :0
at optionValuesHandler.initPimaxValues (System.String pitoolResponseData) [0x00424] in :0
at TCPClientConnection.Update () [0x00013] in :0
(Filename: Line: 0)
2020-10-01 22:11:03:063 :[Debug] Updating SysInfo valuesâŚ
2020-10-01 22:11:03:063 :[Debug] Updating/refreshing Main-SettingsâŚ
2020-10-01 22:11:03:106 :[Debug] Main-Settings updated!
2020-10-01 22:11:03:106 :[Debug] Updating/Refreshing Quick-SettingsâŚ
2020-10-01 22:11:03:130 :[Debug] Quick-Settings updated!
2020-10-01 22:11:03:130 :[Debug] Initializing HMD values from PiToolâŚ
2020-10-01 22:11:03:131 :[Debug] Init HMD values done!
2020-10-01 22:11:03:131 :[Debug] Active Advanced Image Adjustments loaded from active profile
2020-10-01 22:11:22:715 :[Debug] PiTool Connection: PiTool Responded and Settings are Applied!
2020-10-01 22:11:22:715 :[Debug] PiTool responded! Active settings: {
âcomboFov1â: 1,
âfoveatedâ: true,
âfoveatedcomâ: 2,
âhiddenareaâ: true,
âpanelModeâ: 0,
âsmartfillâ: true,
âstartaloneâ: true,
2020-10-01 22:11:22:727 :[Debug] Updating SysInfo valuesâŚ
2020-10-01 22:11:22:727 :[Debug] Updating/refreshing Main-SettingsâŚ
2020-10-01 22:11:22:766 :[Debug] Main-Settings updated!
2020-10-01 22:11:22:766 :[Debug] Updating/Refreshing Quick-SettingsâŚ
2020-10-01 22:11:22:787 :[Debug] Quick-Settings updated!
2020-10-01 22:11:22:787 :[Debug] Initializing HMD values from PiToolâŚ
2020-10-01 22:11:22:787 :[Debug] Init HMD values done!
2020-10-01 22:11:22:787 :[Debug] Active Advanced Image Adjustments loaded from active profile
