Awesome glad to hear they got things working!
So what did he do ? what resolved the issue ?
They applied a series (~4) of firmware updates and ran a âlighthouse watchmenâ update of some sort.
Well looks like it only worked right after my session. Turned on my system after work today and same problem again - base station not detected wtf!!
I wish I knew how to use the lighthouse_watchman_update.exe they left on my system. Running that program with some parameters did the trick last nightâŚ
@PimaxQuorra @alex.liu can you ask the tech the parameter used to get lighthouse tracking working with the util he left on system?
Maybe this will help.
launch the lighthouse_watchman_update.exe under the folder of C:\Program Files\Pimax\Runtime
command line 1ďźlighthouse_watchman_update.exe âbw3
command line 2: lighthouse_watchman_update.exe âBw3 0x90030006
After finished, power off and power on the headset again, restart the service
That worked!! Excellent thank you!!!
Any idea why this had to be repeated after I rebooted my system? Hopefully this isnât a daily requirement
Now I just have to figure out how to stop the random micro jitter!
Anytime mate glad it worked for you!!
Sorry no idea why you need to repeat it. Mine is acting up as well, it keeps losing tracking with the
lighthouses. also got the random micro jitters lol
The micro jitters are terrible for me - almost making it unusable. There must be something going on with the headset, firmware or pitools as many of us seem to be reporting the same problem.
I think I figured out my tracking and steam vr shutdown playing iracing. I start iracing thru sim commander which is my direct drive wheel software. I missed software update in sim commander and that was what seemed to mess up steam vr. Crazy!
