Left eye blurry with parallel projections enabled
I noticed the left eye became significantly more blurry than the right eye when parallel projections is enabled. I can increase the SS to a high level which fixes it a little. Is this a known issue? Currently seeing this effect in Elite Dangerous. It looks like it has something to do with the FOV setting. Setting it on small FOV seems make it better as well. I attached screenshots below
left eye
right eye
@Meteo
See if you have FFR enabled. I have been getting that in Boneworks and it was the FFR.
That was it. disabled FFR and everything is clear again. Thanks
