Leave pimax connected...?
So i finally received my Pimax 4K and its working wonderfully. Im really impressed with it.
Now my problem is i leave my laptop running 24x7, because i find its more easy for me with my life style.
Is it ok i leave 4K also connected (USB+HDMI)? or whats is the easiest way to temporarily shut down it?
Thanks :slight_smile:
You can. But i recommend strongly when not being used for extended time to power the headset off via the power button & disconnect hdmi & usb. Reason? If the headset ends up turning on & staying on you risk potenial screen burn in.
