03/01/21
Latest PiTool (.268) does not allow Large FOV in 5kS.
As title states. Have tried with 120hz and 90hz; “Large” FOV does not appear as an option.
5k Super
215
V1.0.1.268
Not sure, but PiTool says it’s the latest.
Two Valve base stations.
System Info
Windows 10 Pro
Intel I7 6700k
16GB @3200mhz
ASUS Maximus VIII Gene
EVGA 1080Ti FTW3
Latest Nvidia
Latest
Latest
Attachments (Pics/Video etc…)
I can run 90 and 120 on large fov on my 5K+ and so one would think the super should handle it. I would add, however, I am using PT 261 and FW 255 though.
I’m not the only person with this issue; there is a reddit post from someone who has the same problem, as well as another commenter: https://www.reddit.com/r/Pimax/comments/ljjc7c/no_large_fov_option_for_pimax_5k_super/
This is the 5k Super we’re talking about. The hardware might be slightly different.
What Refresh rate are you using? I see Huang responded with refresh rate “Diagonal” limits(They should use real Horizontal FoV values). It sounds like will need to file a support ticket.
I am using 90Hz. It also didn’t show up with 120.
Hello,
We suggest you to file a support ticket and share the # to us, so we could forward to the related department on this issue.
Sincerely.
