Thankyou Quorra
Anyone have a link for 2003, the one above is not working
Thankyou Quorra
Right click and save target as.
Hello,
I have sent you a private message containing a file, kindly check your inbox for it.
what is the latest fw for 8kx 2075? can i use 2003?
Last FW released is 299
be carefull with this software if you use windows 11. was stucked in DFU mode,and cmd commands did not help.
i have a pimax 8kx dmax win11.
here the solution if you get same Problem.worked great.
https://www.reddit.com/r/Pimax/comments/ryataq/warning_virgin_windows_11_and_pitool_causing_dfu/
i had told them this already a month ago…
i hope they listen too, as pimax crystal is out now.
And i ran into this issue.
learned it myself that i had to do what the reddit you linked said.
(kinda googled and looked around)
But yea, they need to update that driver for W11…
Hey,
The 8KX headset does not have a firmware version specifically labeled as “2006v.” However, if you are looking to enable the 120Hz mode with your headset, you could consider downloading the firmware version labeled as “2003v.”
Cheers.
Hi, I want to install beta firmware 120 Hz, please send me the latest beta, thank you.
