We now have a laptop cable for both 8KX and the rest of the headsets in stock.
This is not an adapter but a short extension cable (1M)for your existing cable.
We have two models. One for 8KX with one DP 1.4 8K 60hz to mini display connection and two usb 3.1 connections.
The webshop is still only available in Swedish so if you have problems with translation then just contact us at kontakt@povvr.se and we will manually create an order for you.
If you live outside EU then use kontakt@povvr.se and we will create the order without VAT.
