My experience does not correlate with that. Just 1 game as an example:
I start my pc and start pitool to get my base stations tracking.
I then start assetto corsa via content manager.
The game starts up.
I decide I want to tweak fov so i quit the game and steamvr, then apply & save fov change in pitool.
Then I restart the game via AC’s content manager, NOT pitool, the fov is changed as expected.
Other games work the same way, msfs, american truck sim, euro truck sim 2, PC2, vtol, alyx, etc.
So i don’t know why u say u need to start through pitool? Maybe there are some games that u have and i don’t that require this for some reason, idk.
Which is in line with what I’m observing in my tests. The latter two are similar resolutions and produce nearly identical pixel rates. Pitool 1.5 is showing slightly less bad 0.3% lows. But by the numbers, it seems like very small variations in the results are probably going to change in either direction from driver version to driver version and possibly even run to run.
I’ve observed that kind of small variation in my own testing. Certain resolutions produce slightly better results than others in terms of pixels/sec and jitter which I expect is due to slight oscillations and harmonics of timings. I look for clear trends that stand out from the noise. And I have found a number of such trends, but I’m just not seeing that with pitool quality vs SteamVR resolution setting.
What you’re saying is not actually in conflict with what I’m saying.
The key here is that you are manually applying the settings that you want for the game when you do the “apply & save” step above. That’s also a valid way of doing it. Before you startup SteamVR and whatever game, you can set the various settings in pitool and then apply, and those are now the active settings, and they will be there for whatever game you launch next through any means you like.
What the pitool game launcher does is allow you to setup up and save per game settings for each specific game rather than having to do it manually every time. The advantage of doing it this way is that you don’t have to twiddle the individual pitool settings before you launch the game. You don’t have to remember what you’ve been setting them to. You just launch the game from pitool, and it will automatically do the “individually twiddle all the settings to what you wanted and then apply” for you before it launches SteamVR and the game.
So this is strange. The other day I was playing PC3 on normal , then while the game was running i adjusted fov to large and then small and i could see the effect right away.
I also adjusted backlight brightness and it worked.
As well as color settings.
I know it was increasing the fov correctly because there was no distortion I could now see the sides of my f1 car correctly.
So fov can totally be adjusted on the fly. Its actually way more useful setting the mask change sizes.
Sorry , yeah that’s what i meant. You dont need to launch from Pitool you just need to Apply.
All pitool does is let you save settings per game.
Hitting Apply has the same effect as launching it.
If all you want to do is changes something and relaunch you can simply make your change and launch from pitool or cluch apply and launch it from any other place.
Normally i dont use Large because the massive pixel increase isnt usually worth the performance drop.
But what shocked the heck out of me was how much of a difference it made when sitting in an Open wheel F1 car.
And the only reason I noticed it was because i had switched on the fly from normal to Large.
The only reason Large is worth it specifically for these cars is … You can see the sides of the cockpit next to your shoulders and it really gives you the feeling of hurtling at 200km/h in a coffin on wheels.
Also because your centered in the car when other cars and track walls are next to you they are literally “next to you” I was spotting cars right beside me.
In a normal sedan type vehicle because you are on the left side of the car and the only view of the right side is the passenger window it doesn’t have the same effect and I can easily set it to Small FOV and be quite happy.
Now what I really want is a hot key to switch FOV settings on the fly so that I can get the Large FOV when I need it and toggle back and forth to see the difference easier.
Any Ideas?
I know Autohotkey can target specific UI buttons and press them, but since pitool is using some weird Qt library i not sure it would work
Is there some registry setting or shared memory hack that can toggle that setting?
