Here is some stuff u can try easily and is worth as shot:
Try to use another socket for your power adaptor (even power circle), sounds like this occur with all kind of electrical devices from time to time.
Also try to make sure you have no light equipment running in the same socket, especially dimmable.
Switching the power connector 180 degrees helps sometimes as well, at least with German plugs. (not possible to do it with every plug around the world)
