Got my 8KX today. The FOV and sharpness are great.
But, when using lighthouse tracking I have a constant tracking jitter like micro movements in and out. Even with the headset placed on the table. Ive cycled between Lighthouse and 9-axis, restarted pitools, steamvr, redid the calibration in pitools and steamvr, restarted computer etc etc. With 9-axis tracking mode (internal giro) its fine.
I have a single lighthouse but that was a never an issue with the 5K+ or Index. Newest pitools and firmware according to pitools.
‘constant tracking jitter like micro movements in and out’
‘Never an issue with 5k+’
‘With 9-axis tracking mode (internal giro) its fine.’
Try going back to the 5k+, with exactly the same setup, with the headset in exactly the same place (on the table) for at least the same amount of time.
If the 5k+ still works well, but the 8kX doesn’t, and your lightouse setup is reasonably sane, then very sadly, it would seem highly likely your specific 8kX unit has some hardware problem. I would guess there is a bad connection, fog, physical obstruction, affecting one or more of the lighthouse receiving photocells.
My experience with this pre-production unit is that the 5k+ and 8kX tracking works exactly the same - supports both lighthouse versions, new/old controllers work, similar dropouts when deliberately obstructed in the similar places, etc.
You might try it with each lighthouse 1 at a time and see if the issue persists. Move the LH positions and test as well. As was pointed out usb device drivers can cause microstudder in some rare cases (like the ASUS RGB lighting). You can also try gyro mode just to make sure the issue really is LH related.
