it would be freaking nice if;
Pimax adhered to convention and put the frakking Pitool version number in Help…oh yeah ‘cause there ain’t ‘no flipping “ about”?
Chas
Chas
Can you try posting this again?
It’s very unclear of clarity.
Each pitool version is clearly identified. Though the Update check doesn’t work.
Guess I‘m blind. Perhaps Sir, you would be kind enough to clearly point out the Pitool version number, that would certainly clarify the original request…
thanks so much!
C
Click on 2nd tab. One part on 2nd tab will give version number & option to check for update. General? Hmd will have firmware.
Pitool install also contains version number.
Power is out so can’t fire up computer to do screenshots.
This link should help in forum as it has a couple screenshots.
https://community.openmr.ai/t/faq-getting-started-5k-8k/9468/3?u=heliosurge
As Helio mentioned… pitool version is shown here: … click SETTINGS… and you should be on GENERAL…
next to current version is the Pitool version, there is also a button to check for any newer versions
if you want to know what the firmware version is… click on the HMD on the left…
the firmware version is shown there… and a button to check for newer versions
Eno
