Is there any way to view Steam VR settings "in game"
I just started playing Derail Valley and the game mirrors on my entire monitor while playing in the headset so I was wondering if you can view and change the Steam VR settings like super sampling scale in my headset? Thanks
I am not sure. But from my understanding the monitor should act like a mirrored/cloned display. Rendering goes to say the headset & mirrored on the desktop.
Your Steamvr SS should be applied to headset.
EDiT: yes FPSVR will show you SS settings in game.
Ok but doesnt the SS in SteamVR automatically adjust to whats best for the headset, Problem is I cant see what SS is in SteamVR cause when I turn on the game in headset, my whole monitor mirrors the image so I cant get to my desktop to view SteamVR settings :frowning:
The program FPSVR will overlay in the headset. It costs under $10.
Good for tweaking settimgs as it shows fps & cpu & gpu timings.
Ok, i have that, yes its very helpful. It shows SteamVR SS settings??
Yes if you look it will show Steamvr SS.
In game I think it’s total value.
On desktop for sure alt-tab if in game to bring in focus it shows Global & per ap value.
Thx! 2020202020202…
With fpsvr you can even change the steam ss on the fly both global and per app. Depending on the game if works or not though.
