Just wondering if the 5K+ is using the same LCD display from Oculus GO, because they both are LCDs and have the same resolution. If that is the case I will personally be a bit disappointed because I was hoping for a lower SDE than on the GO. But I was also hoping for a wider FOV and that they surely delivered.
If there are some testers owning the Oculus GO, can you please compare the two displays. Thank you in advance !
