I have been keeping an eye on the latest VRGO Mini-move. I am not sure how comfotable it would be for long gaming sessions moving it that way, but I of course wouldn’t write it off without trying it out.
I have also tried a few locomotion options for VR. I have also have the the Cybershoes and reviewed them. My reviews can found at;
Where I have used the PC version of this controller, I have not reviewed. But here is some gameplay footage using it - - YouTube (it has a live mirror of the controller in the bottom corner of the video)
I have also used the PSVR version of the 3dRudder controller, which works in the same way, and reviewed that. You can find these reviews at;
Yeah thats what I get from it, was why I was thinking would it comfortable for longer game sessions. The foot motion option is more natural then moving your body about.
If you happen to have a spare smartphone with a gyro you might be able to repurpose that instead of getting and messing with an arduino because i know there are multiple apps that translate phone lean into joystick axis.
To get something like the 3d shoe thingies you might be able to repurpose a regular mouse for each foot, make a new tops to get them flat, or extract the sensors and to them out in front of the toes or on the sides, put them on shoes and figure out how to grab the signals and translate somehow.
I have both the cybershoes and 3drudder. And the 3drudder gets 0 playtime. CyberShoes are so much better.
but they aren’t perfect. I feel like they are overpriced for what they are.
I think they could make a home focused version that was more like an actual rubber sandal meant to be worn barefoot or with socks. And they could do something to allow side ways movement.
maybe a combo of Cybershoes and VRGo mini for strafing could work.
I would think the seat thing wouldn’t work that great, as it would keep you from being able to crouch or get on the ground, as well as keeping you from leaning around corners and such since you’d trigger directional movement doing so, if I’m understanding its function correctly.
For me, if I’m gonna sit, I’m also gonna use an xbox controller. Otherwise I’ll be on my feet and want full range of motion available to me.
