Ok so the 8K the should have over 8 million pixels per screen
The plus should have about 3.5milliin pixels per screen
So one would expect over double the amount of pixels for the 8K, yet you’re only counting an extra 30%. Where have they all gone? That’s pretty damning.
i was thinking along the way how the display might have come into existence
if you start with a 4k rgb lcd @60hz (like in the pimax 4k hmd) and ask the manufacturer for the same display @90hz you will get a “no way” but if you get creative and the limit is about the number of subpixel you can hande at 60hz there might be the option to reduce the number of subpixel (the pentile way) to get 90hz and you can still call it 4k (the tv and mobile phone people do that trickery all the time so its no legal problem, there are loads of 4k tv’s with a “lesser” subpixel count)
so maybe thats the “custom” in the type of lcd used, less subpixel with higher refresh?
@SweViver I guess that your 6D and the Macro Extension Tube could solve the problem with just one single shot on a white background, focusing with Live View at 10X. Would you have time for that?
Duuude …you’re having a probably uncharacteristic bad maths day!
Firstly 0.66 means 5K should have 34% less than 8K.
Secondly it would mean 8K would have 50% more than 5K.
Thirdly that’s irrelevant as only one dimension. Should be an extra 50% squared because it’s 2 dimensions which is 1.5squared which is 2.25 so an extra 125% pixels (or multiplier of 2.25). So an extra 30% as counted by Geoff in two dimensions (eg by area) is REALLY low!!!
I know it’s kinda hard to believe. I may have to do my own pixel counting…
Now if you take into consideration 9% improved sharpness from smaller panel size we could estimate that the 5k+ being closer to 70% meaning the 8k would have 30%. Now for buddy estimating it at 30% more pixels would mean that it’s “missing” the other 30%.
So maybe the math a bit off as it now shows that 30% would be likely the correct difference with the 5k having 33.4% less than the 8k.
Mate, you’ve lost me. I haven’t figured out what you’re trying to say, so perhaps you could expand on it a bit? Often formulating the details helps us understand if we make mistakes.
I was kind of deliberately being pessimistic, on most of my counts i made it 50%, some are harder because of the obvious blurring which I am attributing to the upscaling, so i would rather put up a pessimistic number and have people call me out saying “i make it more like 50%” - my main point is that this claim that its G/RB and therefore half the pixels it should be I don’t think stacks up to scrutiny.
also the stuff about the 9% way off imho
the claim was that the 5k+ display has a 9% higher pixel density, so its completely off to assume more pixels somehow, the number of pixels is still 2560x1440
the only thing would be to say the 8k is not using 20% of its resolution, so you have to substract that amount of resolution
and the 5k+ its the same 20% but the 9% better ppi is making that value smaller (its not like you could just make it 20% - 9% the wasted area and a higher ppi are not the same)
To compare the 8k to the 5k+ you need to take this into consideration. If 5k & 8k panels were the same size the 5k+ being smaller has a highter ppi which would use more native resolution from the 25601440 in the viewport vs the orig 5k. So you need to consider the viewable resolution is higher on the 5k+ & would be equivalent to a higher resolution than the 5k’s 25601440(lower ppi).
8k on X axis is 150% longer & 150% taller on the Y axis.
8k has 225% more density (area X×Y) than the 5k.
The 5k+ however has an increased ppi vs the 5k. To compare this to the 8k we need to know how this ppi would translate in a panel.the same size - ie if 5k & 8k panels are 5" & the 5k+ is 4.5" them we need to see what the resolution would need to be at 5" with that ppi.
