Edit the openvr file as pointed out by @XabbuSwe any indexcontroller updates will need to be manually moved each time with @mmorselli fix. But yes great work.
Cool both solutions were presented quickly & are quite simple. Power of community! Wonder what fix(es) was attempted for pitool.
How do you guys install the driver over steamdb? If i use the link in steamdb, my steamclient download the knucklesdriver but the folder in steamapps is absolutly empty. Their is a folder inside “SteamVrKnucklesDriver” called “EmptySteamDepot” but also no files there. Please help
Yepp, thank you. First time i copied the content of the zip file into the EmptySteamDepot Folder. Second time i´ve done it right and now it works. Precision of Finger Tracking seems a little klunky for me, but maybe this gets better with newer pitool version.
Index Controllers need some time to auto-calibrate… make sure to have the latest firmware (connect them with the cable, or pair with the dongle if you have them, without the PiTool services active) and over time the accuracy will improve
@mmorselli i didn’t update the firmware of knuckles cause the steamvr showed it’s updated already. I was pretty sure something is off tho. How should i connect them with a dongle and update the firmware without pitool running?
Close PiTool, from task manager stop pimax services ( PiServiceLauncher and PiService ), if you have dongle (Vive Trackers dongles or Steam Controller reflashed dongle) … or Vive headeset, pair knuckles from SteamVR e see if new firmware is available
PiTool prevents firmware check…
Or connect with USB cable and do the same (I never paired controller via USB, so I don’t know the exact procedure)
