New owner of an 8KX
Trying to get rid of somes problems like audio, ipd, etc, but most of all : Index Controlers not tracked !
To summarize : controlers are detected (menu button works) but not tracked… If I plug them to an usb port, they are tracked, until I disconnect them…
I have to plug /unplug several times to make it works…
To be more precise, I think I have to :
start them
plug them
power them off
power them on
unplugged them
Pitool 273
Fw upgraded to 299 ( 90hz working now )
I had a valve index, eveything worked fine for the tracking ( 2x Lighthouse 2.0 )
With the Pimax 8KX, i’ve correcly paired them
They are recognized ( and in steamvr, when I press the menu button, the menu appears )
But doesn’t show in steam vr home or any game …
I have to do the steps mentionned before to make them works … Everytime
Hello, thanks for your reply
The index is already unplugged
Pairing is not a problem, it works successfully ( using pitool, pressing the B and menu button )
It’s the tracking that doesn’t work, and requires those weird steps of plugging the controller ( not pairing them again, just plug / shut down / power on / unplug )
I’ll try runing pitool in admin mode before launching steamvr
I’ve tried running pitool in admin mode, like PimaxQuorra suggest
But when I do, i can’t start SteamVR ( application doesn’t respond … then I had a “duplicated screen” message, but no duplicated screen in windows options … And nothing was showed in the headset
I reboot the computer normally, and launch pitool normally : same scenarion ( doesn’t respond, then headset was black )
Had to delete steamvr.vrsettings and chaperone_info.vrchap , to make steamvr work again …
And I go back to the initial problem : controller not tracked, unless plugged in, or plugged/unplugged several times before fully recongized
