I only want to say that Today I got a “flash” and tested IL 2 with FFR Active - it’s finally working like a charm !
Tested FFR conservative over 1h at Bodenplatte map and it’s not crashing like before. I can finally enyoy this sim with ultra settings on my “old” rtx 2080ti and PT 1.0 + 100% steam vr res at normal FOV, 75hz.
Wow, I will try it then again. Thx for informing it.
I allways have for IL-2 on my 5k+ vertical resolution about 2200 (2300 max), or else I do not see far contacts. With FFR I will leave current resolution (ss), but I can bump my fps and graphic settings.
Anyway, I love to play other games with large fov and max ffr = max ss!
EDIT: @Yata_PL It is working with conservative settings, but not with more than that. I will test it more in next days to be sure it is always working!
Original (old) message:Yata that does not work for me; I just tried and my game stuck in less than 5sec after respawn
No, it is not working. With conservative ffr it is better, but it hangs after a while also. Unfortunately.
It is tempting to imagine some IL-2 or pitool update will one day give this possibility, but…
As long as IL2 does not change the rendering mode, the crash is normal. I used to enable FFR on the dogfight server to play smoothly for 30 minutes, but it crashed as soon as I entered the WOL cockpit
I dont know why I’m so lucky - ZERO freez here and playing everyday ~ 2 hrs , Single , MP , QM - all maps , just perfect. Meybe nvidia drivers or meybe becouse of stable FPS
I just tested this, and while conservative FFR worked for me fine with vanilla clouds, the moment I installed the Realistic clouds mod, it froze on mission start.
A pity, as that was the main reason for me to want to use FFR.
