Do you experiencing screen flickering when map is loading ?
I have Pimax 5k+ (204 after RMA) and have only 65/90/120 hz modes but in my previous Pimax 202 I had 72hz mode which I like the most for Sturmovik. Do you know a way to get 72 hz in my HMD revision ?
so you default dx.ini file is for normal FOV , yes ?
Everyone experiences the flicker, even non-Pimax users. It has been introduced in a SteamVR Update, and affects some games that have no dedicated loading rooms.
The panels in the SN204 can do 65/90/120Hz, so you have to pick one of them, there is no 72Hz mode available.
Yes, the default file I provide is for normal. If you look into /bin/game/ you’ll see there is the default file, a copy of it called “d3dx_user - normal_FOV.ini” and then the one for wide FOV called “d3dx_user - WIDE_FOV.ini”.
