Jugón Virtual had the chance to try the HTC Vive Pro and the Samsung Odyssey and says that images with the Odyssey are far better, because in the Vive pro you can see the lenses.
Off topic, but you can do a lens swap in the original Vive which makes a big improvement. I think the lenses in the Odyssey are the same as the GearVR.
It took me about 10 minutes to do the mod (including removing the lens from the GearVR). This is a pop out / pop in replacement and a 5 minute update to the Vive configuration. All listed in the post referenced above.
They also remind me of the ones in the PSVR in terms of the shape. I have found that some colors cause a weird chroma effect on the odyssey but mainly within the Cliffhouse have not noticed it when playing fallout 4 vr.
By the way does anyone know what card he is using? Cause that is a huge texture pack!
The Odyssey is truly the VR standard to beat right now. If you have a powerful rig to drive it then VR is truly a thing of beauty. DCS, PC2, FO4VR (heavily modded), SkyrimVR (heavily modded), ED, Pavlov, etc. All work flawlessly with the Odyssey. Having the joysticks as well as the touchpad is just icing on the cake. When Samsung comes out with a 200+ degree highres headset I will be one of the first in line to purchase it. Till then I’m good.
