Ok, LONG story short, was planning for a rather in depth VR setup. Plans changed but plans changed well after the campaign. So, I have an 8k Headset only (no base stations or sensors to detect it). What would be the best way to do a basic video test? So far I can get a green LED and a “grey” display but nothing else. I just want to verify the unit works.
What I do have is a PC that exceeds the specs so, thats covered at least. Just wondering if i can even test it at all (Steam shows it as asleep “move headset to wake it up”)
If you set it up for seated vr you can just start steamvr and it’ll show up
Remember to disable the lighthouse tracking in Pitool.
Gamepad supporting 3dof games/experiences and VorpX. Till controllers/lighthouses get ready drivers and support would be better I assume. Just wonder if our pimax’s will survive till that time with all those cracks and holes on the upper left side especially…
You can run Google Earth if you start the demos from the mirror on your desktop.
Yes many games you can test, you should have a gamepad though.
You can even use a mouse for some apps/games. Simple VR Video Player is one such program.
Yeah.
I recommend every newbie to VR to first fire up the Luckys Tale with the Pimax, it looks awesome and runs great at Pitool max 1.25. Needs a gamepad tho.
Maybe the GoogleVR is possible with the keyboard, idk. It’s pretty awesome, you can go to Angkor Wat or the Statue of Liberty FREE without polluting the Earth.
