How to play Oculus SDK game with the Pimax 4K VR?
We know that at present we can download more game based on Oculus SDK on the Internet, but may not be very clear how to use Pimax 4K VR to play these games, then we will introduce how to use Pimax 4K VR to play Oculus SDK games.
Some players feedback the games based on OC0.6, OC0.8, OChome (1.3) SDK are more popular, then we will introduce the games based on these three SDKs.
Note: the games based on different versions of SDK requires a different drive to play, between OC0.6 and OC0.8 and OChome three are not compatible with each other. The most simple to understand: playing different version of the game require a different driver (different mode). So many players may encounter, how I can not play this mode of the game?Do not worry, just switching to the corresponding mode.
The games based on OC0.4、0.5、0.6 SDK.
  1. Players download the games based on OC0.4, 0.5, 0.6 SDK to the local.
  2. Players switch to the extended mode in Piplay.
  3. Just run the game.
  4. Since the game developed by the extended mode DK runs by default in the main screen, so you need to run the game after you manually set the Pimax 4K VR as the main screen, so that the screen will be directly into the Pimax 4K VR.
    Advantages: low requirements for graphics cards under extended mode, the compatibility of the graphics version is high, the low configuration PC can run.
    Disadvantages: extended mode operates cumbersomely, Windows BUG will easily cause the desktop icon position chaos when switching to the main screen
The games based on OC0.7、0.8 SDK
  1. Players download the games based on OC0.7、0.8 SDK to the local.
  2. Players switch to the direct mode in Piplay.
    Advantages: the operation of direct mode is simple, more games, the quality of the games has improved.
    Disadvantages: high requirements for graphics under direct mode, the compatibility of the graphics version is requested.
The games based on OChome SDK
  1. Players download the games based on OChome SDK (above OC1.3) to the local.
  2. Players switch to pimax mode in piplay.
  3. Open Steam VR.
  4. Use the plugin to run the downloaded OChome SDK games
    Advantages: simple operation, high quality of the game.
    Disadvantages: high requirements of graphics.
It’s useful and clear.:slight_smile:
Thank u for sharing!
