Got it running with the two Oculus dll in game directory.
Start menu is showing twice. One before me is mirrored and the one in the back has the right orientation. Pressing the VR center key shows the right one before me.
In the car the vision is somewhere between the knees of the driver, no chance to center it correctly. Got it one time running ok but both displays were flickering (as running on low hertz)
Okay so I initially had Dirt Rally on Steam. And I used to play on my Rift.
Iāve navigated to the install folder, which is in steam apps. Iāve created the text file as per the instructions, and iāve copied the dynamic link library files into the folder. Iāve also navigated to the .exe in Pitools. Iāve tried launching it from both within the folder, and from within Pitools. And nothing doing.
I am using the latest beta branch of Pitools. Only received the headset yesterday. As yet no extra tracking solution (basestations etc), just the headset.
Without parallel projection, lighthouse tracking and SteamVr/Revive. Runs so farā¦ but the screen was still flickering (like a stroboskop). Then reduced graphical settings to minimum and the flickering was mostly gone - not completely. At some point of a stage the flickering was back. Somtimes the screens go complete white. The whole picture feels unsettled, like running only at 45 hz
I dont see the benefit. I have lower graphic quality and no tracking as running with ReVive. Have i missed something?
Works great. Thanks! No lag in tracking which made the game unplayable with revive. First I had flickering of the screens but then I reduced rendering quality in pitool to 1 and set 90Hz refresh rate and then it worked well.
Try doing room setup in Pitool, and set the HMD to around 150cm while wearing the headset and then calibrate. Vertical should be better, but recentering just moves horizontal like you said. @masta2k9
Mine works perfectly. I am using Nolo VR controller with lighthouse tracking option off. Maybe thatās how? Why donāt you just try with headset only without lighthouse tracking just for a test.
Hmm I get odd centering issues as well. Sometimes it will centre correctly and itās great having the extra performance this brings over the revive version but most of the time Iām to the left of centre and pressing the recenter button in dirt doesnāt correct this, only the orientation but not lateral offset. I donāt use lighthouses. Any ideas?
