Several vr games do not have snap turn. I hate that, as my hmd cable is really expensive.
This is my workaround for such abandonware:
LINK TO DOCUMENT (wordpad file)
PS: It works on any SteamVR game any headset, thanks to “OVR Advanced Settings”
Hi Joe Awesome. Have added you to Guide Maintainers Group. There is a Subcategory there called maintainers.
Nice, Is there a workaround to get the smooth motion turn for games that are only snap action?
Yes, similar as snap turn, you need to bind smooth turn. Check OVR other settings, probably you can fine tune your smooth turn there.
