Yeah I have two tiny pieces of dust under my lenses and have for as long as I’ve remembered with my 5k+. Luckily for me, I literally can’t identify them in VR as they are just outside of the sweet spot. I’m sure I could see them if I stared at a green or red solid color, but I just live with it. I’m well out of warranty and I still don’t know if I want to take it apart. Hot shower to keep dust out of the air isn’t exactly the best method but it might work.
you can remove and replace the lenses super easy with a suction cup, and theres even a 2nd layer of glass protecting the screen. if the dust is between the lenses and that glass then it’s a no brainer to pop it open and clear it out. if its in the chamber with the screen you’re out of luck.
Yeah I was in GEVR for another hour last night after my previous post and it is only noticeable on static, solid patches of color, and only when I look down, and only when I’m also moving my head. Might be why it took so long to notice. So I definitely stopped noticing it after I mentally reassured myself it’s not that big a deal. If it was in my sweet spot I’d be pretty pissed though.
If it ever gets worse, I might have to give that a try. I have taken a few phones apart so I do have the tools for it.
The mesh around the lenses are permeable. Wiping the lens with the cloth statically charges them, any dust that got inside the headset then sticks to it.
