How does Motion Compensation work with the Pimax 5k+?
I saw nothing under Motion Compensation in PiTool.
I guess they currently support only some devices . Its not working with Simtool that for sure.
SimTools is just the software that controls your actuators/motion. Motion Compensation is part of SteamVR. What does SimTools have to do with Motion Compensation?
I have Simtools on, and with Matzman666’s openvr input emulator settings, it works for me.
I’m wondering how do you turn on the motion compensation WITHIN pitool?
There should be the controllers and/or the tracker ID listed in the Motion Compensation pull-down menu when they are available. When you select one, it seems to anchor it to your playspace so it you move that controller/tracker it moves your view around equally. Motion compensation seems to work, I am surprised there are no offset values to set. I assume we are to try to get the tracker as close to our head as possible since we can’t tell it where the tracker is in relation to the headset?
I see that the motion compensation dev work stopped and some people are trying to get some new devs to continue working on it.
Eventually it will break with a steamVR Update.
