I’m thinking of buying the eye-tracking for my 8K+. I do not want to damage my HMD. Any information would help. I do not need it but would like to have it.
It won’t damage your HMD. The eyetracking is attached to the headset with magnets and/or two-sided tape.
Does it support prescription lenses for glasses wearers I wonder? Thank you.
Yes, thats what they told us.
Thank you for your reply.
I can’t tell if your using sarcasm or you are serious.
What about the existing 5k+ i assume the connection can use the top usb-c?
You can see the USB-C connector in the video as far as I remember.
Looks like it’ll fit the top USB-C connector.
