So I have the room scale SteamVR guardian bounds but they are not showing up in my 8KX. It is a miracle I haven’t gotten injured while using my Pimax, but I have lightly hit objects with my controllers though.
How do I get the guardian bounds to appear? During Pitool room setup, it never asked me to trace the space.
Heliosurge that is correct. I ran PiTool room setup, and then steamVR room setup. Defining your play space is the last step in the SteamVR room setup. Following that, the chaperone boundary worked as expected.
