I actually saw this, but only got it once and I wasnāt sure what caused it, it scared me half to death because I thought my headset had a faulty part.
I donāt use pi home but have the odd time had a graphical glitch. Though not the rainbow requiring a hmd reset & once in awhile maybe a reboot. Maybe a pic shift itās been awhile. Have had Skyrim completely exit/crash.
I have had it quite consistently if I change refresh rate, just about every time I do it. Restarting a couple of times generally sorts it so havenāt really been too worried about it.
next time it happens instead of rebooting. try changing the refresh rate in pitool. For me it causes the headset to reset the display and will fix it. So i think its a software bug.
I think I well need to try to get a new cable as well. But i feel like it could be a software thing. But that may not make sense because everyone would have the issue.
I actually had this issue on Day 1 of recieving my pimax. First power up. I almost had a stroke. then i rebooted and it went away. But it woyld cone back occassionally.
I dont tend to change refresh rate to often so that probably went i didnāt notice it as much but now this pitool version which allows different refresh rates per game itās happening enough to cause concern.
FYI guess how many times this has happened on my htc vive, rift, psvr and odessey combined.
A big fat zero. We are so used to bugs now that we are accepting then as normal, when itās definitely not.
I also do not understand a little why this is happening from the cable.
But just in case I would like to replace it with a new one.
Hopefully the Pimax will send it out soon. While - are silent. I donāt even know how fast the ticket system works
Please some one at pimax fix this. I got an email from the support today
This is Wythe from the Pimax support team, we have received your feedback.
I'm sorry you have such a issue.We carefully checked the forum you sent us.
Whether this problem occurs when the frequency is switched, and it needs to be reconnected to restore the power.
Our software department has confirmed that this phenomenon is a bug that currently exists with switching frequency and part of just starting up.
We will check if the issue is related to the line.
We will continue to follow up on this issue, and I will notify development colleagues to follow up. development will fix it first through the software. If it can't be solved, we will change the cable for you.
It may take some time, any other feedback, please let me know, your information will help us a lot.
Have a good dayļ¼```
so hopefully this goes to the right people
We have confirmed that this problem is caused by the switching of the refresh rate.
The temporary solution is that the plug and unplug the power cord will return to normal.
At present our engineers are conducting in-depth analysis and may need some time, Our future solution is solved by upgrading Pitool and firmware.
so they seem to have acknowledged that it is a software bug and will be fix in an upcoming pitool.
