Hook up to alienware ASM100-6980 with windows
how do hook up to alienware ASM100-6980 with windows 10. It only has 1 hdmi port.
Hi David.
You will need to hook up PiMax to the Hdmi port.
To hook up your computer monitor or tv with hdmi you will need an adapter
Display port 2 hdmi or Dvi 2 hdmi
From skimming forums the Hmd(PiMax) needs to be plugged into the first actual Hdmi port.
Hmmm just looked up your machine does it only have 1 hdmi in & 1 hdmi output? No other display out?
If so then do you know if the hdmi can be configured as an output?
If it can’t may need an outside the box option.
Ie Usb 2 video out (usb video card)
A steam link may work to display on TV or monitor.
Understand the above are ideas not sure if will work.
Hopefully support will have some insight or a user who may have similar setup.
There is a discussion in steam about Alienware Alpha with HTC Vive. By the looks of it the Alpha is not likely to work.
https://www.google.ca/url?sa=t&source=web&rct=j&url=https://steamcommunity.com/app/358040/discussions/0/350533172687925852/&ved=0ahUKEwiEzqmDxZPSAhXDOxQKHXZ6ANwQFggwMAM&usg=AFQjCNE_uwNxqC6L1ErrN94eE-YVU_RyjQ&sig2=eNX9zueNtizmBBVePN4P0w
