Hi!
Don´t know what happened but I don´t see the Pimax “black & white screen with the logo” in the goggles anymore just my desktop in a weird dual mode!
Tried to change the displays in the display settings but no luck.
What to do? Thankful for help!
Hi, normally this issue occured if Piplay would be installed incorrectly? Please disable anti-virus software for a while and then reinstall Piplay.
Please add our skype: support@pimaxvr.com if you’re available.
Thank you. Now it works again. Installed the new Beta.
